just got my ex4100, has 4 - 4 tb drives
two I put in, lights under thos are red not green
also I want two different sets
two 4tb as a raid and the other two 4tb as another set
cant find anything to help me
help please
ty
help please
ty
Hello aroff,
Yes, you can do this after creating two volumes of each 2 4TB drives and configure them under two different RAID volumes. You may follow below steps in this regards:
First, remove 2 drives from My Cloud EX4100 and keep only 2 drives
Login on My Cloud dashboard and configure new RAID volume. You can refer below article to configure RAID set up in My Cloud device:
https://support.wdc.com/knowledgebase/answer.aspx?ID=12965#4-bay
After completion of first RAID configuration, insert the remaining two hard drives in My Cloud enclosure
Follow the same process as above to create second RAID volume
Note : This process is Data Destructive and cannot be undone. Once the process begins, ALL THE DATA ON THE DRIVE WILL BE LOST.
