EX2 Ultra - Firmware upgrade problem
I run 5.16.105 on my EX2 Ultra and want to update to 5.17.107.
If I select update the download goes to 20% and get stuck.
If I update from file the upload goes to 100% and says file not found.
I rebooted the device, verified the file - no change.
This doesn’t help.
Get the following error:
root@MyCloudEX2Ultra /usr/local/sbin # ./updateFirmwareFromFile.sh /mnt/HD/HD_a2/Public/WDMyCloudEX2Ultra_5.17.107_prod.bin
cp: write error: No space left on device
It is probably from this line in the script
cp -f ${filename} /usr/local/upload/newFirmware
but there is plenty of space.
Nothing happens, just the prompt returns
root@MyCloudEX2Ultra ~ # df -i
Filesystem Inodes Used Available Use% Mounted on
/dev/root 14336 2387 11949 17% /
devtmpfs 16198 738 15460 5% /dev
mdev 16198 738 15460 5% /dev
ubi0:config 0 0 0 0% /usr/local/config
/dev/loop0 8249 8249 0 100% /usr/local/modules
tmpfs 0 0 0 0% /mnt
tmpfs 0 0 0 0% /var/log
tmpfs 20000 97 19903 0% /tmp
cgroup 16198 12 16186 0% /sys/fs/cgroup
/dev/sda4 258048 22 258026 0% /mnt/HD_a4
/dev/sdb4 258048 23 258025 0% /mnt/HD_b4
/dev/md0 244060160 619403 243440757 0% /mnt/HD/HD_a2
I have the same problem. :tired_face:
