I was having the same problem numerous times. Yes, rebooting helps, but I am towards stability, so I have figured out how to start the crawler again without rebooting the whole device.
Below are the steps you need to perform:
Ensure you have SSH connection enabled in the WD My Cloud network settings
Connect to My Cloud via SSH and enter below commands to the console
/etc/init.d/wdmcserverd restart;
/etc/init.d/wdphotodbmergerd restart;
/etc/init.d/wddispatcherd restart;
The output should look like this:
WDMyCloud1:~# /etc/init.d/wdmcserverd restart;
[ok] Stopping wdmcserver: wdmcserver.
[....] Starting wdmcserver: wdmcserver9498 (process ID) old priority 0, new priority 0
. ok
WDMyCloud1:~# /etc/init.d/wdphotodbmergerd restart;
[ok] Stopping wdphotodbmerger: wdphotodbmerger.
[....] Starting wdphotodbmerger: wdphotodbmerger9649 (process ID) old priority 0, new priority 0
. ok
WDMyCloud1:~# /etc/init.d/wddispatcherd restart;
[ok] Stopping wddispatcher: wddispatcher.
[....] Starting wddispatcher: wddispatcher9721 (process ID) old priority 0, new priority 0
. ok
WDMyCloud1:~#
Crawler should be started by now and you should start seeing a green flag in your WD dashboard > Content Scann.
During first few minutes it will show that Scan Completed, but 0 files are processed. Don’t worry, soon your old numbers will be back and if you have any changes to your media library - it will start scanning.
It took 5 minutes to restore all the library in my case.
Hope this will help. Cheers
