hi
I have two Tv shows on my WD Tv live media player.I have watched both episodes so i know the play ok.But when i try to delete them i get the following
Error code 0x80070570
No matter what i do i cannot get these two items to delete.Anyone got any ideas or tip on how i can resolve this matter ??
You mean other than attaching that drive to your computer and deleting them there?
Thats how i normally delete file attch to Pc delete the move over more new files.Is there another way to delete files ?
richUK
4
Search the internet. This error means that the files are corrupted.
ERROR 0X80070570: ERROR_FILE_CORRUPT.This error is due to The file or directory is corrupted and unreadable. .Â
I cannot find any easy way for this problem to be sorted. As a last resort you could remove any other files and re-format the drive.
I had thought of that option myself.But as my WD has @ the moment 140Gb of movies & Tv prog,s it will have to wait a while
Cheers
Try a full disk scan, and tell it to scan for and fix errors.
It’s possible this happened due to not “Safely Removing Hardware” before you pulled it.
