Hi all! Trying set up wireless network. Is there any way to enter the wireless-code thru the Webb-interface or cut and paste the code in any way. The code would take forever to enter via the remote.
Not from the web interface.
But you can use any usb keyboard you have lying around.
Thanks, that’s a workaround but not an acceptable solution. For security reasons I have a rather extensive code its a pain to type. This forces people to use simple security-codes.
think you can pass any text to the player via remote from computer, so i assume this code should be possible too.
just write what’s need and click on submit and it should appear in your player
Not shure what you mean. Is it possible to copy text from a text document and enter it as wirelesscode?
Yes i guess, with WD Link Tool, then go to virtual remote and paste the code into remote then click on submit.
and the code will be passed to the player
Or do it via the WD Remote App on Android or IOS, or via the Web Remote built into the SMP’s Web UI.
Thanks Zebra9 and TonyPh12345 I think I got it Will try later!
