As I keep evaluating the WD TV LIVE HUB media Center Player which I purchased recently, I would like the WD community made aware that the DVD_VR recorded ISO files do not play with it’s menus at all it just sits there with a blank screen
The same DVD_VR recorded ISO Files from my LITEON-DVDRW DVD Recorder LWV-5001 using which I have created tons of Home Video recordings do not play in WD TV LIVE HUB Media Center Player the same plays fine in WD TV Live Plus with the BETA firmware Beta v1.03.43
There is definitely some Bug in the official FW Release 2.02.16 (10/26/10) in this regard, It also manifests itself wherein certain ripped DVD ISO file Menus also do not work but it rare hit and miss.
As you may have already seen one of my previous posts wherein if Media Library is turned off, playback resume function fails with Release 2.02.16 (10/26/10)
Please add this new *BUG* wherein certain DVD ISO’s created with DVD_VR recording technique by some hardware based DVD Recorders fail to present DVD Menus in WD TV LIVE Hub unit.
BTW, the same files play (WITHOUT menus ofcourse) if you attempt to play them in PREVIEW mode, Obviously that Piece of code is different than playing with DVD menu code.
WD If you are reading this post Please make a note of this *BUG* Please investigate this matter and fix the problem.
Thank you.
Best wishes
