I was recently informed that MyBook Duo's automatically encrypt the hard drives. I wasn't aware of this.
The other day I decided to see if the drives in my MyBook Duo was readable outside of the enclosure and it appears they are NOT.
I pulled both drives, 4TB WD Red's, and put them into an Inateck Drive Dock and plugged it into my computer. The drives did not appear (I tried both disks individually), in Disk Management, they appeared as UNFORMATTED/UNALLOCATED disks, and Disk Managment wanted to format them so I could use them.
I put them back into the MyBook Duo, and plugged it into my computer, and it worked fine.
So, what am I to make of this? Does that mean the MyBook Duo encrypted the drives so nothing but the MyBook Duo can read it? Is there any way to turn this off? Because now I'm really concerned for the safety of my data. It's nice that it's Mirrored, but NOT nice because I'm stuck with this ONE enclosure that can read my data.
Anyone have any ideas about what I'm seeing?
Dower
