Sorry…I think I pasted wrong…
This should be the correct version:
smartctl version 5.38 [arm-marvell-linux-gnueabi] Copyright (C) 2002-8 Bruce Allen
=== START OF INFORMATION SECTION ===
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WCC4N3DXUEFJ
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 9
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Sep 11 23:29:39 2017 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 243) Self-test routine in progress…
30% of test remaining.
Total time to complete Offline
data collection: (40080) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 2481
3 Spin_Up_Time 0x0027 182 179 021 Pre-fail Always - 5883
4 Start_Stop_Count 0x0032 096 096 000 Old_age Always - 4803
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 6
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3780
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 10
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 8
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 4807
194 Temperature_Celsius 0x0022 101 094 000 Old_age Always - 49
196 Reallocated_Event_Count 0x0032 194 194 000 Old_age Always - 6
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Short offline Completed without error 00% 3775 -
2 Short offline Completed without error 00% 3770 -
3 Short offline Completed without error 00% 3769 -
4 Short offline Completed without error 00% 3769 -
5 Extended offline Aborted by host 40% 3768 -
6 Extended offline Aborted by host 90% 3764 -
7 Extended offline Aborted by host 90% 3764 -
8 Short offline Aborted by host 10% 3764 -
9 Extended offline Completed without error 00% 3734 -
#10 Extended offline Aborted by host 90% 3727 -
#11 Extended offline Aborted by host 10% 3727 -
#12 Short offline Completed without error 00% 3716 -
#13 Short offline Completed without error 00% 0 -
#14 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
