After successfully setting up using my Mycloud drive last year. I have tried to add new files to it today and the drag and drop does not work. When I try I get a red circle with a line through it.
This happens when I am going fronm my PC to the my cloud drive.
It works OK the other way around IE from my cloud to PC drive.
This is your third post asking about this. Did you read the information I provided before and if so what happened.
Provide some images if possible showing what is happening.
Are you dragging them to a share or a folder in a share?
