It might be because I’m using a crappy USB cable but so far neither OSX or XP seems to see the Hub.
Isn’t it supposed to be plug and play?
Any suggestions on this concern will be welcome.
Well, the HUB is not a USB-Device, so no Way, its like connecting two PC’s with an USBCable, it will not work!
Its possible to connect USB-Devices to the Hub but not possible to connect the HUB to an USB-Port and accessing the internal HDD this way!
Understood… However, do you know the reason why Mac OSX 10.4’s finder can’t display the hub whilst leopard can?
