As above really, looking to get a new hard drive for storage and wondered whether the WD TV Live has enough juice to supply a 2tb 2.5" USB powered HDD reliably or whether i’d have to go for a 3.5" externally powered one? Are HDD sizes limited to 2Tb in order to be recognised by the WD TV Live box?
They work great if you hook them up to a powered use hub, then the hub to the WD. That’s what I did. You can pick up a 4 port powered hub for under 20 bucks on Amazon.
Actually, I’ve been using bus powered drives exclusively since 2011 and the still worked fine. I own some WD passports (largest is USB 3, 1 TB) and also tried Intenso, Verbatim and some others without any issues.
