i believe it is time for WD to change the indicator lights in their system, the blue LED light is not comfortable and I cant sleep at night, i wonder if WD can tweak their software in the DL2100 to reduce the light intensity?
There’s an idea suggesting said improvements:
https://community.wd.com/t/adjust-led-brightness/67528
I’d recommend “liking” the first post to show support for the idea.
I ended up putting tape over the LEDs.
