HI;
I have the HD TV version.1 and been experincing problem with alot of DIVX movies. The issue is visiable after 10 or 15 minutes of movies when sound and picture are out of sync. The movies are in DIVX format and are converted correctly. The all can be played without any issue via PC, XBOX, Laptop (Windows Media Player, VLC and etc).
Also I have tried on another media player box “CYCLONE MKV” and it plays prefectly. After contacting WD support and alot tracing, I have been advised that WD HD TV box does not support DIVX and I need to convert more than 200 movies to another format.
Has anyone tried a proper DIVX movie in AVI container? what is the divx codec version sed for the movie? (Can you send me the video information)
At the moment I am not using the WD and it is packed in its original box becuase it is useless and can not get refund neither from PC World shop or Western Digitial. I have been told they can not do anything and they are not prepared to tell me if it will be fixed in future. Western digital has been very disappointing so far and wate of money.
(The box has been used for 1 hour max)
Here is information on one of the movies I have problem with:-
Video:-
ID : | 0 |
Format : | MPEG-4 Visual |
Format profile : | Simple@L1 |
Format settings, BVOP : | No |
Format settings, QPel : | No |
Format settings, GMC : | No warppoints |
Format settings, Matrix : | Default (H.263) |
Codec ID : | DX50 |
Codec ID/Hint : | DivX 5 |
Duration : | 5h 21mn |
Bit rate : | 1 072 Kbps |
Width : | 720 pixels |
Height : | 480 pixels |
Display aspect ratio : | 16:9 |
Frame rate : | 23.976 fps |
Standard : | NTSC |
Resolution : | 8 bits |
Colorimetry : | 4:2:0 |
Scan type : | Progressive |
Bits/(Pixel*Frame) : | 0.129 |
Stream size : | 2.41 GiB (95%) |
Writing library : | Lavc51.40.4 |
Audio:-
ID : | 1 |
Format : | MPEG Audio |
Format version : | Version 1 |
Format profile : | Layer 3 |
Format_Settings_Mode : | Joint stereo / MS Stereo |
Codec ID : | 55 |
Codec ID/Hint : | MP3 |
Duration : | 1h 57mn |
Bit rate mode : | Constant |
Bit rate : | 128 Kbps |
Channel(s) : | 2 channels |
Sampling rate : | 48.0 KHz |
Stream size : | 108 MiB (4%) |
Alignment : | Aligned on interleaves |
Interleave, duration : | 24 ms (0.58 video frame) |
Interleave, preload duration : | 24 ms |
