I currently use the Z drive for a removable drive for software that is already setup. Is there a way to change the My Cloud Home Drive to something other then Z?
Thank you
Thank you
If Z: is already taken WD discovery should use the previous available letter. I have 2 my cloud home and one mounts as z and the other as y.
If you are using z for a removable make sure it is connected when you sign into the my cloud home account in wd discovery so z is not available.
