I got a mybookworld ethernet edition and i have very large files to transfer from it to my computer. Therefore, is it possible to transfer files directly with cables instead of over the air using my wifi network… I am currently transfering at 1.67 MB/sec, which will take me 15 hours to transfer all my files… Maybe we can use USD or Ethernet cable between the drive and my computer to have a faster transfer ?
if this is possible, what could be the procedure ?
Plug your computer into your router - that should speed things up signifigantly. You could try plugging the drive into your computers NIC port, but that’s hit-or-miss depending on a lot of factors.
Well, after having restarted the WD and plugged it direct to my computer ethernet port, I try to map it //mybookworld/public or even //mybookworld or even with its IP address but I got an error message in windows saying it cannot access the network. Of course, at this time, I am not connected to the internet since my drive is directly connect to my ethernet port.
