hi! i have a 4 TB NAS myCloud and wanna buy a Ups Apc Bx650ci-ar Bx650 model. anyone know if it will recogniced by the NAS ? thanks so much
Hi diegoacco ,
Unfortunately, we haven’t tested our WD device with it.
Thanks!
Okay, more generally then…
What facilities do the MyCloud series offer to support integration with a UPS?
Is there a means by which a UPS can instruct a MyCloud to perform a safe shutdown when the UPS determines it has nearly exhausted its battery?
This could be done by the UPS logging in via SSH, and issuing a shutdown -h now
command.
Some UPS devices connect to the USB port. If you look at the /usr/local/modules/scropt folder on the gen2
My Clouds they have two scripts called ups_action.sh and upssched-cmd just not sure what models they work on.
Okay, I understand how it works, we agree. The problem is: to try I must buy the UPS. if I buy and then do not recognize it I’m fried. I plan to plug the UPS through USB into the NAS. I should see that recognize it in the control panel of my cloud
If your My cloud has a control panel. It is not a single bay My Cloud. You need to go to the forum for
your model.
I was trying to get our WD Staff member @peter.g to give some guidance on the facilities the series provides, and how those facilities are invoked. Rather than a glib comment that it hasn’t been tested.
There’s nothing in the user manual about UPS integration.
Maybe I expect too much, but I think if WD staff are going to post on the forums, they ought to be a bit more informative…
Dream on.
I thought I’d ask google support.
https://www.google.co.uk/search?q=my+cloud+ups
And, lo! I found this:
https://support.wdc.com/knowledgebase/answer.aspx?ID=17214
Looks like our basic MyCloud doesn’t have UPS support. Or, at least, not that they’re officially supporting
