So I have been trying to rollback my firm to 2.04.13 with absolutely no success. I can roll back to different firms but nothing from 2.04.13 or earlier. It says
“The Firmware you are attempting to install is not compatible with this hardware. Please check http://support.wdc.com for the correct firmware to use with this hardware”
I have been using the link provided on these forums so definately not getting it from some other website.
Any ideas ? My hardware is fairly new and have been wanting to run the Aoenish theme.
Yup, Definately the live hub. The earliest firmware I have been able to revert to is 2.05.08 from that page.
If there is anything else you need to know I will let you know. Been running aoenish hub beta with no issues on a new firmware but his final release calls for 2.04.13 as there is no newer menu mod.
