Device is offline with a slow breathing light for several hours
Since yesterday afternoon, my Cloud Home storage which is a 2TB has been offline. It started after a power cut and hence it never came back online.
It keeps on with a slow breathing for several hours but never a steady light.
I’ve tried to
  1. unplugged everything, wait for some minutes and connect everything back.
  2. Factory reset - 60+ sec and the detach device from mycloud.com
I already created a support case and until now, I did not receive any updates.
Can anyone help on this?
Hi hishaamn,
Please refer the following link: Slow Blinking LED and Device Offline on My Cloud Home
We were unable to locate you in our system with the available information but would suggest you give us a call with the support case number, we will definitely look into it.
To Contact WD for Technical Support:
