DataVolume and swap are not being mounted / no device nodes in /dev
Hi, looks like similar problems appeared but a topic is closed already.
The deal is that mountDataVolume.sh can’t mount sda4 (DataVolume) and sda3 (swap).
Also no /dev/sdX device nodes are present.
Maybe this is the cause but I’m not sure.
kernel.log says that mounting data volume failed with code 35.
Would be thankfull for amy kind of help.
Regards,
Alexander
That’s an extremely old thread… What firmware are you in?
