gappie
1
I am seeing a “Data volume failed to mount” error message and a red light on the fornt of my WD My Cloud. I tried the steps listed at this link http://community.wd.com/t5/My-Book-Live/Data-Volumes-failed-to-Mount/m-p/556170/highlight/true#M20534, but had no luck.
I also tried to do a full factory restore and a hard reset from the button on the back of the device.
I dont care for the files on the device. How can I just reformat and repartition the device?
jubei04
2
Hi gappie, welcome to the WD Community. Have you tried using another Ethernet cable?
gappie
3
Hi, thanks for the reply. Why would another ethernet cable make any difference with this problem? The NAS is connected via a router to my PC.
Use nfodiz’s Debrick procedure.
jubei04
5
A Red light will appear when there is no Ethernet cable connected or a faulty one is used. You can also check the guide that Tony is referring too.
http://community.wd.com/t5/My-Book-Live/GUIDE-How-to-unbrick-a-totally-dead-MBL/td-p/435724/highlight/true
