Data Recovery from 1TB WD Portable Hard Drive
How can I recover data from my 1TB Portable External Hard Drive that is making a clicking sound when plugged in to the USB Port but does not show up on the PC when connected?
Sounds like the “Click of Death”. Check out this earlier post. You can also web search and find many similar issues.
If your drive is making a clicking sound it likely has a serious mechanical issue. I suggest you start by checking different cables, ports, or another computer if the drive becomes recognizable. If it occasionally shows up use Stellar data recovery software to scan and recover files if the drive isn’t recognized and sound continues use the professional data recovery service, as they can handle hardware issues. I would highly advise you to stop using your drive before going for these methods.
The clicking sound is a red flag. It usually indicates that the read/write heads of the hard drive are hitting the platter incorrectly. This can happen due to mechanical failure or physical damage.
When your hard drive starts clicking but doesn’t show up on your computer, the safest and most effective thing to do is contacting a professional data recovery service. They have specialized equipment and clean room facilities that allow them to open up the drive and attempt to recover your data.
Hi! Did u manage to solve the issue with your WD Elements external hard drive hard drive?
I’m not the one with the clicky drive. The person who posted has not been back to report on progress. bear in mind this was back in 2024.
