Please advise best sources of information and/or tutorials for data recovery and hard drive maintenance to facilitate CCTV footage recovery after a DVR or NVR has been recovered from a building that has had fire damage or excessive smoke has filled the building during a building fire.
Hey there, Theo.
Basically when there has been fire involved the best and most reliable options would always be a professional solution, such as a data recovery company. That’s why if your data is really important, I’d suggest you go straight for that - Data Recovery.
On the other hand, if you’d like to try recovering this data by yourself, you can give it a go with some data recovery tools to see if you have any luck. Note that if the drives have sustained physical damage, this could complicate things a lot more if you decide to go for a data recovery company later.
Hope that helps. Good luck!
CK_WD
Stellar Windows data recovery software ( https://www.stellarinfo.com/windows-data-recovery.php ) is best for recovering files from the hard drive. You can download this software on your Windows system and can easily retrieve your files from any type of storage device.
