Well, my drive is now showing the Capacity in the UI and WD Quick View.
I’m exhausted from working with this, so I hope this makes sense.
This is my second My Cloud.
The first one would not show the Capacity and got stuck at 90% on the Diagnostics Quick Test.
I took that one back to the store and got the one I currently have.
It did the same thing.
I called WD about the drive getting stuck at 90% on the Diagnostics Quick Test and they had me do a Quick Restore which fixed that problem. About 10 minutes later I tried the Diagnostics Quick Test again and it got stuck at 90%. My solution to that was to Shutdown the My Cloud, unplug it for 10 seconds, and plug it back in. That fixed that issue.
This drive showed the Capacity in the UI & Quick View when I first got it.
Then I put 140,000 files on it and it no longer showed the Capacity in the UI or Quick View .
I tried everything I could think of to no avail, including Shutdown the My Cloud, unplug it for 10 seconds, and plug it back in.
So I called WD. They had me go through all the basics and finally wanted to send me a replacement. I insisted they elavate the issue. I felt another one would just do the same thing. They are going to call me Monday.
In the meantime…
I disabled DLNA Media Server, iTunes Server, and Cloud Access.
Then I noticed that when when you went to the Shares page in the UI and clicked on each Share it would show you how much space was used. I did that and put it in a spreadsheet. I also turned off Media Serving for al 9 Shares.
Then I got an email from the support ticket I had entered which suggested:
How to reset a WD My Cloud, Mirror, EX2, or EX4 Personal Cloud drive
http://wdc.custhelp.com/app/answers/detail/a_id/10432
I used a paper clip to hold the reset button down 4 seconds, but it did not reboot. So I tried 7 seconds, but it did not reboot.
So I did a Shutdown and went and did other things for an hour.
I came back and unplugged it for 10 seconds, plugged it back in and went away while it started up.
When I came back I found that the Capacity in the UI & Quick View were working!
Also, the Content Scan was finally Idle (after about 4-5 days).
It had been Idle occassionaly during that time. But then it would start back up.
So now it is working.
I wish I could tell you what did it…
