Copy Speed
I have purchased 4TB HDD.
I am able to access it as a Network storage after login into the WD app and copy files using my Windows 11. However, the speed is very slow.
How can I increase the speed of copying the files into this disk and from this disk to my Windows 11 system.
Thanks in advance.
Deepak
@DeepakMalhotra
Have you been to the WD web site and checked to see what the read/write speed is for the HD you purchased?
All Hard Drives: Shop Internal, External, Portable HDDs | Western Digital
You posted your topic under the sub-topic for the My Cloud Home.
Copy process is dependent on the slowest link; in this case, the read/write speed for the HDD.
Other examples: if you were copying via USB port, it may be because of a USB2.0, 3.0, 3.1 difference that could increase speed. Don’t know where you’re copying from so I gave this as a potential problem.
#WDUserRewards
