I’m trying to connect the MBL to office LAN, which has 802.1X/PEAP with MSCHAPv2 authentication.
Do I have any chance to make it work? If I just connect the MBL to the lan, the led eventually becomes green, but I cannot find it from the PC.
Thanks,
Alberto
Well, I’d start off by asking your corporate IT for help.
Alberto,
LANs can be setup many different ways with all types of security. Without knowing what exactly what the LAN topology is there are too many variables to troubleshoot.
Like Tony said, getting your IT to help is probably your best bet, if you cannot find the device by just plugging it into the network.
