On my router, I have tried forwarding both ports 21 and 8021 to 192.168.1.15 on port 21, but I always get a CONNECTION REFUSED response. My router seems to working fine, and is handling port forwarding properly otherwise.
My purchase decison was based on this funcationality, so any advice would be appreciated.
For pasive mode, you nave to open ports 5000-5099 in the router too. You can change the settings in /etc/vsftpd.conf via ssh.Install filezilla client for connect to mycloud. It´s the best option to connect it.
