Hi all,
since a lot of days I never tempt to, but now it does not work anymore
I can not anymore connect to the dashbord to views and change the parameters and settings.
- I gave the login/pwd and validated
- The webBrowser get the dashbord, and functions for a few seconds and then it disappears and the logon page would be resend…
- If I tempt to map a network drive from my laptop connected by wire to my local network it does. So the logon and the pwd is correct.
- through the web \local-IP\UI and during the first second it works, I can see the dashboard is responsif.
it gets the diverse functions for continuing…
but just after the logon is reset… - If I tempt to connect to the shares it works , getting files and puting files it works.
but connecting to the dashboard does not work…
what 's wrong ?
I does not see what to do …
Is anybody can help ?
thanks in advance
