I have a the passport pro and for some reason my TV and the passport do not communicate. Even through PLEX. Is there another media device that I can use to bridge the two? I tried the Micca spec but it does not read the original formatting is GPT and Micca uses MBR. I have already loaded several movies to the passport and do not wish to delete everything and change the partition. Is there anything that reads GPT as a media device?
Hi DevinG,
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
