I want to use a Live TV in my RV (motorhome here in Europe), and so I’d like to power it direct from the leisure battery, not rely on an inverter or being hooked up to the mains. Since the Power Supply output is 12V it should be easy, but of course I need a supply lead that has a suitable jack on the receiving end.
WD can’t help it appears. Does anyone else have an idea or similar experience?
I’m an electrician so am confident I could undertake any technical work required…
Cheers
Philip
PS. I’ve also posted this on the ideas forum.
