My wireless router died and I had to replce it. Now that I have a new router I cannot remember how to connect my World Book to the network. I also cannot find the discs that came with the world book and the software is not installed on my computer. Can anyone point me in thr right direction? Thanks.
Once you connect the drive to the router it should automatically appear on your network again. You don’t need a CD to installed. You can just go to Network and the drive will show there. If you want to mapp it just right click on the folder (public) and select map network drive, after that it will show on Computer.
Here you have information on how to map it.
