My wireless connection no longer works so I need to recover the files via USB cable. Ive connected the MyCould Home device to my iMac desktop but the drive does not show up. Any suggestions for recovering these files?
The USB port is not for connecting to a host device like a computer.
If your wireless connection no longer works … try a wired connection
ie. an Ethernet Cable connected to your Router and the My Cloud Home.
Thank you. But we no longer have a wireless internet as we switched to a Verizon hotspot.
Have you checked the User Manual?
User Manual: My Cloud Home and My Cloud Home Duo (westerndigital.com)
You can check the Knowledge Base too.
A range extender could connect wirelessly with a hotspot and output ethernet to MCH.
Thank you!
