I have a WD TV Live Plus and want to use Netflix
I have a quest dsl and novia for a provider. conection speed is 256k
Netflix will not work at all but youtube does. Although not very fast.
I suspect the conection speed is not fast enough for netflix.
We are viewing on a 26" TV so we may not need the highest resolution.
Quest can change the speed of our connection to 3meg per second.
Now for the question, If I change provider to Quest and the 3meg speed, will the WD TV Live Plus operate Netflix?
PURPLECAT
