Code for remote control WD TV?
My remote control its OK… but I want all remotes in only one
Everyone have 3 digit-code to control WD TV?
many tanks
I have never tried this. And I dont think this is possible. I will recommend you contact WD support directly for assistance with this
Contact Support | WD Support.
Universal Remote controls would have different codes for different devices, so you need to check / contact the manufacturer of your universal remote control for the “3 digit-code”
(if one even exists for the WD TV on your remote)
failing all that … read your Universal Remote Control Inctruction Manual, specifically the section … Programming / Learning Mode
52558…i m just using sony RM-VZ320..
