mbond
1
I stop my brand new MBL and unplug it.
Then I power it again and it reboots ok.
The time/date is then wrong, as if the clock of the MBL has stopped running, and I have to reset it.
Is is the correct behavior? Is it untended that there is no internal battery to keep the clock running?
Thanks for any feedback.
Wizer
2
The clock should adjust automatically
check the settings on the dashboard
As Wizer says, it should update when it boots up.
BUT – The MBL must have a working connection to the internet to get the updated time when it boots up.
It does NOT update if the network is brought online AFTER the MBL is already booted.
