Hi Fox_exe
First of all, I just have to express my admiration for your skills, and your generosity with your knowledge and information and time, your commitment and passion and your desire to share and help everyone grow in this field. You are a shining star and a leader for sure.
Thanks to google translate I can now say: YA prosto dolzhen vyrazit’ svoye voskhishcheniye vashimi navykami, vashey shchedrost’yu, vashimi znaniyami, informatsiyey i vremenem, vashey priverzhennost’yu i entuziazmom, a takzhe vashim zhelaniyem podelit’sya i pomoch’ vsem rasti v etoy oblasti. Vy yarkaya zvezda i navernyaka lider.
I will be making a contribution to express my thanks and I encourage others to do so as well, to the best of their abilities. I dont have your email but I will try to send a donation with the information I have.
I do need your help and have some comments to make. This may be a long post…
My goals are (were) simple -
- Install Debian on my WD EX2 (gen1 not ultra) and then OMV to try.
- After that I wanted to put any stable DSM version on it.
- The End. That’s it.
So I checked out your site and the instructions but even now I dont know what " Look for WDMC-Mirror (Gen1, Its same devices)" is supposed to mean. Are you saying that the files for the WD EX2 and the WDMC-Mirror are the same and interchangeable?
Some of the instructions are not clear and a lot of readers would benefit if you wrote in a simple “Step1, step2” …in a logically ordered fashion. Keeping the cookies on the lowest shelf helps a lot more people reach it and you can help a lot more people.
So in any case, I went to your website’s EX2 folder and in my case the .bin files for Debian in the “EX2” folder dont install on my EX2 through the WD Webgui…in the “Mirror” folder on your website, the only thing that did install was “Debian-jessie-firmware-test” (why is it still called test? is this not working ? Shouldn’t it be a .bin file) and I was able to Telnet into it but SSH didn’t work…and I couldn’t figure out what to do next (partition disks?, fix the sleep issue or the ramdisk ? i dont know the Sequence of what comes next) or even if that was the right file for the EX2…
I couldn’t do anything so I successfully reverted to the stock WD firmware (using your instructions - thanks) . So now I am twiddling my thumbs having used up about 48 hours trying to find a solution…
I understand you are fairly busy with other projects and it seems you have moved on but can you help me with this ?
