We will drop the formatting for now. Run this command will uninstall and purge OMV :
apt-get --purge remove openmediavault
nano /etc/apt/sources.list.d/openmediavault.list
Replace "erasmus" in place "kralizec" deb http://packages.openmediavault.org/public erasmus main
apt-get update
apt-get install openmediavault -y
omv-initsystem
reboot
Test this method already, it’s possible that this is enough
Tried all over from first installing stock fw, upgrade to fw4, clean debian and as posted above by Tony.
update & upgrade: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded
as instructed, GPG and public key error not available msg
openmediavault-keyring
again, as expected error on keyring. E: There are problems and -y was used without --force-yes
so I removed the y switch and tried again.
This time I input without y switch. 3/4 prompts eg encoding etc. After that a very long process…wait…wait…wait…still scrolling txt…wait…“got result success”…wait…wtf more txt…Finally a last prompt to run next step
omv-initsystem
No errors and I know it’s been success.
Reboot
Finally to OMV gui
Many thanks Tony for your help.
Edit: forgot to add that I broke the last tab when removing HD
I installed dsm6 to my mc gen2 4TB. after 12hours , When I login to ds file, “You are not authorized to use this service” message is displayed and can’t login. And dsm manager web ui is not working properly. Maybe synology block invalid user. How can i solve this problem?
After restoring these files all glitches was gone, dsm works properly again.
Note: You can find these files in firmware (.pat) file - Inside hda1.tgz archive. (Use tar for extract both files).
Thank you. Fox_exe
After restoring 4 files and reboot, Dsm manager working again.
But after 12 hours, Dsm manager was not working properly again.
I have one more question.
I enabled hdd hibernation log, but i can’t see hdd woke up log.
And i saw so many “system/system_status_get.c:39 SYNOIO_GET_SYS_STATUS fail” error log in /var/log/messages
Maybe hdd hibernation is not working because of “SYNOIO_GET_SYS_STATUS fail”.
Have you seen hdd woke up log?
I like to try as having problem with tftp. What I want is copy 3 DSM files to USB & connect HD to computer. I’ve already tried by mounting USB. Tar and dd went ok without any errors but failed to boot. Just to confirm: edit path info
(if my usb is /dev/sdd1)
cd /dev/sdd1
tar & dd?.
Frankly, if dms5 was coupled with debian, I would have stayed on dsm5.But I prefer to return to debian + omv (debian see only), alot more flexible for what I want to do, and began omv is updated regularly, not dsm5.All depends on your needs
i have installed omv_2.0.2_Test.tar.gz on my Gen 1 and everything went smooth. did all the update and changed system from RU to EN. and when i looked at the LED light on the drive it’s white. is that normal ?
is there a way i can master reset or i there is a fast way i can reinstall omv ?
If you have access to omv interface, is that it’s good
Of repositories are available, needs more of these files “omv_2.0.2_Test.tar.gz”
If you want the latest version (omv3 erasmus), install clean debian jessie and following this tutorial :
echo “deb Index of /public erasmus main” > /etc/apt/sources.list.d/openmediavault.list
echo “127.0.1.1 MyCloud.localdomain MyCloud” >> /etc/hosts
apt-get update && apt-get upgrade
Yes, normally no problem, but personally I would advise you free backup plugins and then reinstall them.
OMV is capricious at times, I prefer to have a basic backup precaution.
I installed synology for wdmycloud gen 1, and have some problems:
-File copy speed over samba slow, just 20-30MB/s (tried samba v3,and v4) compared original wdmycloud speed, what is 80-100MB/s
When I copy many files from wdmycloud, then after a while (10-15min) connection break, then I click the try again button in Windows, and after 3-4 try copying continues.
I installed tvheadend plugin from http://syno.dierkse.nl/, but I cannot enter tvheadend webuit at 9981 port, because ask me login/pass, but not accept what I gave at installing this plugin. The old one tvheadend from synocommunity I can enter, but not recognise my dvb-t sticks (supported by synology, and built in from kernel 2)
Possible fix this faults, or better to change to OMV?
