there is a guide on how to do it under macbook? which program you should take in order to extract the files and install!
I took unarchiver and VSSH lite to install and get the following error:
WDMyCloud: ~ # cd / Data Volume / shares / Public
WDMyCloud: / Data Volume / shares / Public # chmod + x install.sh
WDMyCloud: / Data Volume / shares / Public # ./install.sh
-bash: ./install.sh: / bin / bash ^ M: bad interpreter: No such file or directory
I have followed your tutorial and have access to the DSM webgui. Unfortunately I get the message ’ no hard disk found’ … What am I doing wrong? Is it because the HDD is still labeled as ‘gpt’?
is it possible to add sfdisk to your Recovery Image with fdisk
this will make it possible to Move to to DSM without losing the data as we can change the partion table
we can change the Data Partion Number to be sda3 instead of sda4 and create the new partions as per the rest of your tutorials
this is an Example on how it can be done with sfdisk
# sfdisk -d /dev/sdb > sdb.bkp
leave a copy for safety
# cp sdb.bkp sdb.new
now edit sdb.new changing ONLY the lines order and partition numbers, as in my case:
from
# partition table of /dev/sdb
unit: sectors
/dev/sdb1 : start= 1026048, size=975747120, Id=83
/dev/sdb2 : start= 2048, size= 204800, Id=83
/dev/sdb3 : start= 206848, size= 819200, Id= b
/dev/sdb4 : start= 0, size= 0, Id= 0
to
unit: sectors
/dev/sdb1 : start= 2048, size= 204800, Id=83
/dev/sdb2 : start= 206848, size= 819200, Id= b
/dev/sdb3 : start= 1026048, size=975747120, Id=83
then throw it back to the disk partition table?
# sfdisk /dev/sdb < sdb.new
My numbering sequence was mangled after I shrank&shifted right the only partition (sdb1) to add two smaller partitions at the start of the disk using gparted.
If the last command does not work, as in my case, change it for:
# sfdisk --no-reread -f /dev/sdb < sdb.new
You can save all data: Just dont format sda3 (Data volume).
But need align data partitions like in original.
Something like this: mkpart primary 1M 2048M mkpart primary 2048M 3072M mkpart primary 4828M -1M mkpart primary 3072M 3106M mkpart primary 3106M 3134M mkpart primary 3134M 3136M mkpart primary 3136M 3138M mkpart primary 3138M 4828M
And don’t run this: mkfs.ext3 /dev/sda3
maybe need check data volume…
just registered to tell you how glad i am that you share your work here. I received my WD My Cloud today and immediately installed Debian Jessie on it - works like charm. Is there a possiblity to donate a few bucks to you?
Unfortunately the network speed is very poor (especially FTP which gives me 3,9mb/s, SCP does 7,9mb/s), but i guess that is a hardware issue.
hi i’ve been using your omv firmware since last year without any problem.
but today i tried to add Google DNS adresses in webgui and something went wrong. since then i couldn’t reach the nas anymore. can you help me please?
i tried with your recovery packet on windows 10 but dhcp gives me this output
Listening On: 192.168.0.1
Network changed, re-detecting Static Interfaces…
Accept Failed, WSAError 10038
Warning: Section [LISTEN_ON], Interface 192.168.0.1 is not Static, ignored
No Static Interface ready, Waiting…
Lease Status URL: http://127.0.0.1:6789
Listening On: 192.168.0.1``
Since you have the knowledge of using the recovery packet. What do you think about the
ability to use the recovery packet to upload a special version of Linux that would capture the log files to the users PC. This would be a great help in determining why a device won’t boot.
Just to be sure. I can use this procedure up to the point of telnet. Once I telnet in I can run my commands. When I’m done I can reboot the My Cloud and it will be back to normal. I don’t want to over write anything on the My Cloud.
FOX you are my man
it worked perfectly, I moved to DSM and all my data are in place and and all the services i had before are up and running in the new DSM ( transmission , Wordpress )
Overall rating 10/10
DSM is much more flexible and Most of my previously made scripts to automate my tasks are already built in with no effort
My WD cloud now is officially a station full of potential not just a dummy SAMBA box
Quick note for who ever would Migrate you might need to install the bootstrap after the DSM installation which will allow you to run and install additional linux commands ( it’s like jailbreak for the DSM ) just search for Easy Bootstrap Installer for synology DS414j
It is not much of effort but other than that I can not complain
