For security issues, I’ve changed the RDC (Remote Desktop Connection) port number to 3397 from it’s default 3389, and after that it only worked one day, since that I can’t access the WD Sentinel DX 4000… it’s working properly with files and on remote web access, but I can’t access it from the Dashboard or a simply RDC connection.
How can i reset it to default configuration or if anyone knows how to access it ? (I’ve tried to access it on port 3389 till 3399 and no response)
I am faily cerrtain the dashboard will never work on a diff port,but am checking for you.
But on the local lan using a desktop if you start mstsc and connect to servername:3397 (colon an the port you changed it to) it should connect to the desktop
I have to go on the road now for 8 hours or so. I have run out of time to tinker, but it looks like it might be possible to connect to the server using server manager from another box. see below. and or a remote registry tool like this. I am not endorsing this have not tried it and it could be a virus for all I know
YEA !! Good deal and thanks for letting us know. Which method did you use?
FWIW, you can look it up, but I think you make that regedit twice and you can have 3389 and say 3387 at the same time. Then you could open the firewall for 3387 from afar if you like.
I am fairly certain that the dashboard may not open on a desktop if you change the port from 3389. I may be wrong. I have asked up the ladder but have not heard anything yet.
