EX4Shot wrote:> FINANCIAL IMPACT ANALYSIS of this defect on the WD EX4: (Tally continues)
16hrs inital triage @ $60hr (average computer tech repair rate) = $960
2hrs on the line with WD L3 support @ $60hr (average computer tech repair rate) = $120
4hrs setting up “recovery rigs/hardware” @ $60hr (average computer tech repair rate) = $240
48 hours into recoveing three drives (a kind estimation) = say at $30per hr = $1440
Still have 1 drive to go, and its the “problem one” that I cant just read like the others.
Still looking to pickup Paragon HardDisk Manager 14 Suite @ $49.95 (supports EXT4) (still looking for sugestions)
GRAND TOTAL (so far) > $2809.95… (and climbing)
I have found several freewares out there that I have been experimenting with.
Couple recomendations by members. (thanks)
No one has been a magic bullet yet.
Paragon ExtFS $0 > has been fairly stable reads well, and seems to copy large files. Pops an error at the end looking for the original folder. “wierd”. But if you just skip it finishes, and so far the few test files I have tried are viable.
Ex2read $0 > has some comments/feedbackl about being old and not handeleing large files. Did not try it.
Ext4Explore $? > Recommended by the commenter on Ex2read, so I have not tried yet.
File Scavanger 4.2 $? > May look at next
TestDisk $0 > Another freeware that is DOS window driven. Trying now. There were several messages in the readme about not reading Ext4 without plugins, and then running 32bit under 64bit wonkyness. Im trying it on the analyse button but so far seems to have hung. Ill let it run for a few hours see if it finds anything.
Ex2FS $? > Driver referenced missing in above software. Havent looked for yet.
ReiserFS $? > Driver referenced missing in above software. Havent looked for yet.
Paragon Hard Disk Manager 14 Suite $50 > Since there free trial befor you buy, I may try this next based on the TestDisk seeming to freeze.
Trying all these options on a 4TB drive is taking a lot of time. I may just bite down and hit Paragon above. That being said though I have recovered about 8TB of data that looks viable. This last one though is still the bear.
I was really hoping one of the major mfgs would have something out there, but majority dont support Ext4 for some reason. You would think that with the saturation of NASs out there and most of them running on Ext4, somone would have see the dollar signs opportunity in thier eyes poping?
@ DavidSucesso, Hope some of these inputs help you recover your drive or at least lead you down a path. But since you were spanned, it may be more intensive…
