Although I delete the files(2TB), there is no space on the disk.
it only frees up space when I delete all data(factory reset)
Firmware 7.13.1-165
Firmware 7.13.1-165
I’m having the exact same problem. A quick Google seems to suggest this is a common problem, but I’m not finding any simple solution.
RohanJoseph gave a pretty good possible solution here and it is pretty straight forward:
