I have followed your steps carefully. It looks as if your new certificate file has been uploaded correctly and, as far as I know the chmod 774 ca.crt command has completed correctly (there is no error message anyway)
On the final step I also get the error message with the last command (i.e. Options error: --nobind doesn’t make sense unless used with --remote
Use --help for more information)
I also still get the error 31520 and a failed internet connection.
I guess I must be doing something wrong but I can’t see what… Any help much appreciated!
We have a few of these drives and it would be really helpful to get them working online again…
Yes, I have rebooted nas many times from the dashboard. And also deactivated and activated remote access many times.
Let me know if wd support tell you something.
I have a double nat in my LAN.
One router (internal) has upnp enabled. The other one (external) has upnp disabled.
This configuration worked until error 31520 appeared few days ago.
Have I to enable upnp on the second router?
Hi everyone. Has this issue been solved? I have exactly the samer issue. I went into the settings and disabled and reenabled remote connection but got the error message “Cannot establish remote access connection. Make sure you are connected to the Internet. (Error 31520)” but the network tab said I was connected fine and I can access my documentrs on mybooklive through the ethernet connection to my PC. It is remote access which does not work.
has anyone found a solution. I am running the diagnostic test but without much hope!
Thanks everyone
Is there a simple solution? Maybe a patch file to download? I am unable to understand the technical solutions. All I want is to access my wd drive on my tablet and phone. (pc works as it is cabled). Otherwise will bin my drive and get a new drive - definitely NOT another WD drive as they dont seen to care.
Update - All of a sudden all the android apps are connecting ok to the drive again!!
This did work perfectly for me, thanks for the update!
I did use the 2nd procedure which looked simpler for me. One hint for mac users : the Winscp app suggested works for PC only, and I am on Mac. I simply used FileZilla and it worked nicely!
Cheers
Hi, i activated UPnP IGD with 10 hops, and updated firmware and updated the new certificate.
WD is online as long as no mobile acces is in place.
any Idea ?
tahnk you
In typical form, the only responses that might have solved the problem have been removed by the f*ckers at WD.
Can ANYONE reiterate the answers that led to success, again, please, and, for the record, apparently hooking a URL is a waste of time, and better idea is to COPY the answer, since the f*ckers at WD seem intent on removing any possibility of correction.
