Can not write to WD ShareSpace after Updating Firmware 2.2.8 with MioNet 4.1.1.9
After updating to 2.2.8 and rebooted.  I can no longer write to the drive.  I can Read all the data.  I am running Windows 7 and XP Pro with all updates.  Can someone give me some advice on how to gain write access back.
I have set all the folders to public with read/write access and still no luck.\
Any help would be appreciated.
The first thing I would do is back up all your data on the device to another location. Once you are done try doing a full factory reset on the device, and see if you are able to copy your data back over.
