How can I use two WB II (white light) drives on the same network without conflicts? For example, since there is no way to disable Twonky, won’t I run into issues with two NAS devices running at the same time? Any insight, warnings or info would be appreciated.
You can two units on the same network as long as there seperate ip addresses. You can kill twonky if you read this thread http://community.wdc.com/t5/My-Book-World-Edition/WD-World-Edition-white-light-freezes-locks-up/td-p/99198
I presume you will have one as media server if you are using, have brought these units. I hope this helps M
