Bypass Router for Networking ... Straight to PC?
Is it possible to leave out the middle-man (router) and go straight to ones PC via RJ45 ?
Seeing that there is a major issue here with networking shares, I wonder how many have tried going directly to their PC.
I would try it but that would need everyone patience in this house while I remove wireless functions for a while as I play around and test.
Has anyone tried it as a solution ? If it were to work, would using an RJ45 splitter work (one to router, one to WDTV) on the PC NIC card ?
Check if the link below helps.
http://community.wdc.com/t5/WD-TV-Live-Hub-General/Connecting-WDTV-Live-Hub-to-the-Internet-via-PC/td-p/105526
I’ve used a 10/100 and 1GHz switch for this purpose and both work just fine, the 10/100 are really cheap now and work great! :smiley:
If you use windows media player and share your media to the network then all your media (audio, photo and video) will be available from your windows OS >Vista PC and this will include USB drives connected to that PC.  I’m using FW: 1.06.41V beta.
Also available your media player folders - playlists, ratings etc.
Accessible from Media Server :smiley:.
When it works its a good little box, pity bout the latest firmware fiasco (ff = 11111111 = 255)
PeteB:smiley:
