When i attempt to connect to the NAS MybookLive I get a red light and cannot connect. It work great for about 2 months now I cannot connect. Nothing has changed…
Try power cycling the my book and connect the Ethernet cable directly to the computer and check if the same thing happens. If it does then the my book might be faulty.
