I have a $5 blockbuster.com credit that’s expiring soon, so I figured I’d check it out.
I have the WDTV Live Plus activated.
When I try to play a preview, I just get a blue circle spinning forever.
I’m worried that if I rent a movie, it won’t work either.
I am in the US.
Netflix, Flingo, etc, work fine.
Any ideas?
Try unplugging/replugging the WDTV first, and then try the preview again.
Same thing.this should work, right? Any other ideas? I imagine if I rent a movie I’ll have the same problem as with previews.
meh531
4
I had this problem for months. I finally did a hard reset (button on bottom of unit) and Blockbuster started working immediately.
Doing the hard reset doesnt delete all your content on the drive does it?
Ok…guess I will be doing the hard reset…all for blockbuster…UGH
