Blinking power and usb lights
Hi, turned on my media player this morning and all that happens is the power and usb lights blink on and off. Nothing on screen. Was working fine last night but appears to have suddenly decided something isn’t right. Any idea?
Cheers
Hi there, did you tried the reset button on the box…? If this will not help, i think is a hardware problem… you should give it back, if have still warranty you have nothing to worry about!
               regards from Athens-Greece :slight_smile:
