Blinking Light after Firmware update? HELP PLEASE
did i miss something with the update? i updated, it said it needed to reboot, now i just have a blinking light and it wont start up? HELP PLEASE.
I already answered you the first time you posted.
That wasn’t really an answer genius. i could have thought of that hence the question being about AFTER the update.
Please contact our tech support. The flash memory in your unit may have failed.
thanks
You make a post with a pathetic HELP PLEASE and then insult people!!
Tony answered your same question with ‘That ain’t good. That usually indicates a hardware failure. Call tech support.’
You have now got the same answer from WD.
As always RickUS WD is so great supporter to customer like honored contributor !
What does that even mean?
Hookt on Fonix ain’t workin’?
That mean that is not great support here !
As i own 2 boxes and test WDLive and Apacer Al670 !
Also as i look support in wd and apacer as i sow it that apacer is more proffesionol than WD for sure !
Have much more organize support and answer is better than here also Help Desk is better !
Here Customer ask for help and only answer what he get is that unit is broken !or that surf and found on forum answer !
He also know that unit is broken and doesnt work, but some kindes and help will be great for customes here !
I dont no what i feel here with WD support and answers as I already posted that is apacer more professional than WD !
As i made more times ticket and same answer for all tickets !
Alright, oceansoul.   I guess I failed.  Please, will YOU provide the correct answer to the OP?
:slight_smile:
Im customer not supporter !
You should no that not me !
I also try to found answer !
Well, so am I, and I apparently had the same exact answer WD had, so I’m still not seeing the problem here…
oceansoul wrote:
:slight_smile:
We are all users / customers just like you. This is a user forum where users help other users.
