So, this weekend my WD Live Hub gets to run a film festival. Which is greatly cool. But need some help.
Where in the themes is the code that tells it to display the video title and the icon of a camera when a video first plays. I want to remove that.
Thanks you!!
I’m supposing that you are refering to the video playbar which is at the bottom when you play a video.
If this is the case, then it depends on your video format. If your videos are in DVD format, then you have to edit the “dvd_navigation.xml”. If your video is in any other format, mkv, avi, mp4 etc., then you have to edit the “video_run.xml”.
@ MatthewFoF
Just a quick’n’dirty edit to achieve what you are after…
Just Video Status Bar, Speed and Time Info: (No Subtitle or Audio Info is displayed as well)
http://www.mediafire.com/download.php?jl7no44gp18z1aj
VCR mode … 100% NO info: (Nothing at all, just Video playback)
http://www.mediafire.com/download.php?2p8v6unuqal11q5
Install them into your themes folder to apply them… this only changes Video and Dvd playback display, all other Mochi code is “Factory Default”.
Joey,
That is it! Thank you so. You’ve just improved the weekend of me and about 3000 viewers.
@ MatthewFoF
No Probs, hope all goes well.
