I did a full re-set, etc. Once updated I re-applied the necessary folders on my MBL NASs to the media library.
Unfortunately nothing on my NASs shows up in the Media Library, so I had a look and tried to re-scan. The SMP refused as it says the folder is set to read-only.
So, I went into the NAS from my laptop, and sure enough it has Read-only’ ticked. Don’t know why, it was definitely unticked before.
So, I unticked it, clicked Apply, clcked okay. Tried again, and the SMP says it’s set to Read-only.
Checked again on the laptop and gues what? That’s right, it’s Read-only again.
Untick. Apply. Click away. Right click. Guess what? Read-only again.
Now it looks like a NAS problem, but this has only happened since updating.
In the Media Library settings, when I click to add places to the library, I used to just get MYBOOKLIVE1, MYBOOKLIVE2 and MYBOOKLIVE3. Now, in addition to these (and listed before them) I get 3 additional sources, each a set of numbers. If I access these they are different links to my MBLs and they allow me to add items to the library.
If I add to Media Library on the NAMED ones I can do it, but only on the first level (straight below ‘Public’).
This is no good for MBL3 as there are some videos on there I want in the library, and some I don’t.
But I can add just one one folder using the NUMBERED (NFS) route.
And, if I access the network on my PC I can remove ‘Read-only’ if I ‘Select All’ folders, but if I only right click on the video folder it removes ‘Read-only’, but then immediately adds it again.
